Fuse 1 Tech Specs
Fuse 1
Print Engine
Selective Laser Sintering
Build Volume
165 x 165 x 320 mm
Build Speed
10 mm / hour
Layer Thickness
100 µm
Material Refresh Rate
Up to 50 %
Startup Time
60 minutes
Connectivity
Ethernet or Wi-Fi
Dimensions
677 x 668 x 1059 mm
Weight
88 kg
Power Requirements
2 kW, 120 or 240 VAC
Optical System
Galvanometers
Formlabs Custom
Scan Speed
2,000 mm/sec
Laser Type
Fiber rated to > 10,000 hrs
Laser Wavelength
1066 nm
Laser Power
10 W
Laser Spot Size (FWHM)
200 µm
Print Preparation
PreForm Desktop Software
File Type
.STL or .OBJ
Nylon 12: Material Properties
As Printed on Fuse 1
Published Value
Ultimate Tensile Strength (XY)
52 MPa
50 MPa
Ultimate Tensile Strength (Z)
50 MPa
48 MPa
Tensile Modulus (XY)
1800 MPa
1850 MPa
Tensile Modulus (Z)
1900 MPa
1800 MPa
Elongation at Break (XY)
14 %
12 %
Elongation at Break (Z)
7 %
6 %
Feature Design Guidelines
Minimum Value
Full Strength / Depth
Wall Thickness
0.75 mm
2.00 mm
Pin Diameter
1.00 mm
2.00 mm
Hole Diameter
0.60 mm
1.00 mm
Slot Width
0.75 mm
3.00 mm
Moving Part Clearance
0.25 mm
1.00 mm
Reserve Your Fuse 1 Today
Be the first in line to receive the new standard in industrial 3D printing. Make a deposit now; beta units start shipping late 2017.
Sign up for our newsletter
Stay up-to-date with the latest in 3D printing news, interviews, and tutorials.
Contact Sales
Interested in designing your Form Cell?
